1.8 vac hose layout
the one in the tech articles. the diagram shows/labels 13mm being used. in the length totals no 13mm is shown. lots of 12mm. what is the correct size?
kevin
Old 01-17-2004, 07:46 AM
Send a message via AIM to jim912928
I just replaced all my fuel lines and vacuum lines based on this diagram. I used the 12mm in the length totals area....everything worked great!
Jim
80 911SC Targa
75 914-6 3.2l Conversion
58 Triumph TR3A
07 Harley Night Rod Special, 08 buell 1125R, 08 Harley CVO Springer, 09 Harley Iron
Old 01-17-2004, 08:54 AM
another difference in the diagram. layout shows 19 and 22mm. material list shows 18 and 22. once it's cut i buy it. what's correct?
kevin
Old 01-19-2004, 11:54 AM
I used the 18mm which worked for me. The 22mm I couldn't find anywhere yet...so I've just ducked tape for now mine (embarrased yes, did it work...for now!). Seems like the sizes in the "listing" versus the diagram are the ones to use (in my case at least...have a 75).
Jim
80 911SC Targa
58 Triumph TR3A
Old 01-19-2004, 12:05 PM
the 914 i bought in oct is a 75 also. po or someone used orange heater hose. looks horrid. thanks again jim.
kevin
here? not so much i think. high five!!!
Old 01-19-2004, 12:20 PM
yw...took me about 2 mos to get it running very well. What I found is if the vacuum lines are all tight, the electrics are good, fuel is clean and pressured...then the l-jet runs great! Mine starts first time and idles great even in this cold Indiana weather! Good luck!
p.s. the fuel line diagrams are also correct and work great! Might not be a bad idea to change the fuel lines also...old cracked ones can start fires! And you never know (in my case) if they actually used fuel line material!
Jim
80 911SC Targa
58 Triumph TR3A
Old 01-19-2004, 12:34 PM
it runs pretty good now. except for the exhaust. i'm going to change to some ss h.e.'s and a 4-2-1 muffer set up that i already have. i have all the other bits and ends. going to tune and do the lines first. not going to make repeated trips to the parts shop. making a pretty comprehensive list. right on the fuel line. firewall back is the plan at this time.
kevin
Old 01-19-2004, 01:08 PM
