New seats
Not being able to afford some high bolster Renegade seats. I tried to make some myself.
Made the bolsters and then did the upholstery for a total of about $70. Need to start on the passenger side soon before I forget how. Bob |
Bob
Nice work. Do you have demensions and materials used. Thanks Mark |
great work, now how fast can you do the rest of ours?
'72, now with a living, breathing 2056... |
Hats off to some fine work!
- "NOW" Magically Delicious - |
You upholstered your seats yourself? Is this something that is easy to do? Did you have a kit? Please explain! I'd love to redo my seats just like you did, but I'm not sure where to begin. The local upholstery shop wants about $1000 to do it, so I would much rather do it myself. You did a fantastic job!
Mike 74 914 2.0L 78 VW Gti 82 VW Rabbit |
But after doing this I found a shop in town that will do the seats for $125 and furnish the materials on my modified bases. I may let them do the next one. Bob |
Bob,
That does look good!!! John
'73 914 (Renegade V8 conversion) |
grind weld build
You sir, are teh king of V8 frugal 914 Scooby delux-ness. what type of filler is the blue?
flesh heals, memories last forever! 73 Orange, CS #601 73 Rayco V8 glug, glug 69 911 w/82 turbo look on 275 35 18s (for sale) Trek 6500+ Sean M! |
Looks good, Bob! Lot's of satisfaction from doing it yourself, too, I'd bet!
I gotta do that myself one of these days. Ed |
Bob,
Those seats look fantastic. Very cool!! How and what did you use to attach the side bolsters. What are the side bolsters made of? If I could figure that out, my local upholstry place would recover each seat for $100. Not in vynil of course. Thanks, Michel |
Oh, sorry, I spoke too soon and did not let the other photos load. Is that 3/4 inch plywood?
Michel |
Its 3/4" plywood like you guessed. I bolted them on and then filled the gaps with body filler (BONDO) this sticks great to the fiberglass and plywood. I then put a couple of layers of fiberglass over it. On the next one I don't think I'll do the fiberglass they seem strong enough with the bolts and bondo. I'd also make the back bolsters a little larger.
Bob |
Here is a better pix of the shape.
Bob |
Hey Bob, that's great! Which car is that? It can't be the CA car, that would be too fast to have it look that good!!
