-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=7)
-   -   idle speed (http://forums.pelicanparts.com/showthread.php?t=159159)
jmargush 04-19-2004 09:09 AM
idle speed
I have a 1.8l with fuell inj and the idle speed climbs to 1500 1900 rpm after driving it. If I start to let the clutch out and the engine starts to pull I can make the idle drop and stay down about 800-100 rpm. until I stop again and it is idling high again. Any idea on a cause and solution for this?
jmargush 04-19-2004 09:10 AM
revise that low idle to 800-1000 rpm
Va914 04-19-2004 10:11 AM
I bet you have an air leak in one or more of your FI vacuum hoses. If you haven't done so I would replace all the hoses to insure you don't have a leak.
Also try plugging the auxiliry air valve hose, if the idle drops..there is at least one of your leaks :)
I have a 2.0L with teh D-jet and it took replacing ALL the hoses with new to get all the leaks under control. It should run you about $40 for the hoses and well worth it :)
Bets of luck
Kerry SmileWavy
jmargush 04-19-2004 12:02 PM
I've done all the vac hoses so I will check plugging the aux air valve
Dave at Pelican Parts 04-19-2004 03:48 PM
Check the ignition timing, as well. Make sure the points plate moves freely, and that your vacuum cannister actuates the advance and the retard. (You'll need a "Mity Vac" or other vacuum source, at least for the advance.)
--DD
