tat2dphreak's Avatar
altenator woes, HELP!
I now a have a running idling 2056 in my car!!
I had an issue today though... I wired everything up... but some how something happened...
I had put a new altenator on, but used the harness from one of my other altenators... I don't know if I hooked the big red wire up to the wrong pole (both poles are marked B+, but 1 is marked with 2 "B+"s)... I initialy used the pole with only 1 B+, I wired this to the starter, the same place as the battery is wired... when the car ran for a second or 2 though... that wire started smoking... we killed the engine, and checked everything out... only that wire was hurt...
I assumed I put the wire on the wrong pole, so I pulled the altenator, used the other harness, and put it on the other pole, wired everything up... but, when I went to put the terminal back on the battery, there was a spark... not wanting to burn up the other wire I unhooked it...
now, WTF do I do to get this right? does the big wire NOT go to the same pole on the starter as the battery (+)? is the pole on the altenator with 2 B+s the right one(that's the one it's on now)? did my inital wiring mistake(?) kill this altenator? could this be the cause of my other electical issues(see other THREAD)
'72, now with a living, breathing 2056...
Old 05-01-2004, 04:33 PM
