Remote oil filter/thermostat mount
I'm in the process of mounting my remote oil filter/thermostat on the undersurface of the rear trunk with the engine/exhaust out. I have no land marks to use. Does anyone have a picture of this area so I can assure myself of an acceptable location. The PP article mounts the remote filter to the vertical engine tin. I want to mount the filter to a more sturdy location such as just rearward of the verticle engine tin.
Thanks, L. Mcchesney |
I mounted mine in the front right corner of the engine compt. That area under the trunk is going to be way hot.
John,
That are is beneath the battery or in front of. Do you mount the filter mount to the engine firewall? Do you not get oil collection at the bottom of the engine shelf? Thanks, L. McC |
