wag wag is offline
Send a message via ICQ to wag Send a message via AIM to wag Send a message via Yahoo to wag
which 914's have "porsche" lense?
I've been checking out the 914 in classifieds and looking at galleries all over the web of pics of 914's and i have a question that i cant seem to figure out. exactly which 914's have the "Porsche" lense (or quasi-lense) at the rear? between the
rear bumper and the rear trunk lid.
do only the 1.8 and 1.7's have that lense? i cant recall ever seeing a stock-2.0 with that lense. is it a preferred cosmetic feature? does it actually light up (kinda ricey, imho).
thanks
Old 06-14-2004, 04:41 PM
I believe this was an aftermarket add on for all three engine types. Some one correct me if I am in error.
'80 SC
Old 06-14-2004, 05:27 PM
Ornery Bastard
None of them.
Some of the lenses were dealer-installed (or so I have heard) but precisely zero 914's left the factory with the red "PORSCHE" reflector in the rear.
Depending upon who did the addition, the stock pushbutton trunk release may have been replaced with either an electric solenoid (as on my car) or with a cable for a remote pull. I would imagine that somewhere, someone has wired lights into it so that it comes on with the parking lights, but I have only seen them be non-illuminated.
Most people whom I have talked with consider the reflector addition to be the 914 equivalent of those silly used-car lot "pinstripes".
Aaron
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 06-14-2004, 05:28 PM
wag wag is offline
Originally posted by AaronM
None of them.
Aaron
hahahaha
Old 06-14-2004, 06:30 PM
Ornery Bastard
Originally posted by wag
hahahaha
Sadly, my car has the reflector and solenoid setup.
Generally, I'm of the opinion that if the reflector setup works, it's a lot less trouble to leave it alone than to replace it with the correct set-up. No need to go around inventing problems with it.
Aaron
Old 06-14-2004, 06:39 PM
Scooter311's Avatar
Heya
IIRC, they were aftermarket (two styles, black letters and 'ghost' letters??), and some have taken a 911 reflector and cut it down to fit the 914.
I have a reflector on mine, but I'm not sad though.
- "NOW" Magically Delicious -
Old 06-15-2004, 05:40 AM
Scott S's Avatar
Before you install one, please make sure you like it. I have never seen so many bloody holes when I removed the one installed on my car by the PO. It was work to get that panel straight again. Not for me - hate 'em.
- A pile of British stuff
- A growing pile of German stuff
... oh, and two Hondas - complete with car seats and pounds of fish crackers smashed into the carpet (and seats, and door pockets, etc etc etc....)
Old 06-15-2004, 07:08 AM
BURN-BROS's Avatar
Ditto, I have a 76 that had it done. The holes that are aparently required to mount the thing are quite large. The double sided tape out there would have been a better solution to mount it.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 06-15-2004, 07:19 AM
Kenny Powell's Avatar
There are after market one's that are offered now that are specific to the 914(that don't require the hole's drilled) I have one on mine.......I like it!(although it is the one that required the hole's to be drilled)
75' 2.0 w Ljet
"I like the way she doesn't move in the curve's... and then she let's go!"
Old 06-15-2004, 07:41 AM
RETIRED
Joe Bob's Avatar
The air conditioning, front badges, rear reflector and radios were dealer or owner installed items.
The rear reflectors were 911 ones that were cut down...in most cases. There were aftermarket 914 ones made for a period of time. You can get a cable pull for the relase instead of the solenoid, drill a hole for the push button or a smaller hole for a nail to be used when the solenoid fails...which IT WILL.
A lot of people will install the solenoid button in the rear of the car under the license plate....rear decklids sometimes need a push down to release when the solenoid is activated....two person job if the solenoid is in the cabin.....unless you have long arms....
2012 ML350 3.0 Turbo Diesel
Old 06-17-2004, 03:43 PM
jhadler's Avatar
"Radios"? That's something that I always wondered about. Were radios included from the factory or were they strictly dealer installed intems?
I always thought they were factory items, have I been wrong? (wouldn't be the first time...).
-Josh2
Old 06-18-2004, 11:17 AM
RETIRED
Joe Bob's Avatar
Radios were NOT factory.....just "period" correct......decade of the 8 Trac....
Old 06-18-2004, 11:26 AM
SGB SGB is offline
SGB's Avatar
I used to like them less untill I saw the one I saw on my brothers 911. If it is done well, it is OK. I don't have one on my car though, or a front crest. I think the crest looks out of place on a 914.
-Scott
My gallery page
Old 06-18-2004, 09:12 PM
914 Geek
Yes, no, maybe so... Brett Johnson lists out a number of radios that were original equipment to the 914. I don't know where he got that info.
My guess (and it is just a guess!) is that some 914s did have radios installed by the factory, while most were ordered without. Then the dealers (or importer?) put a radio in. I'm betting there was a higher dealer profit margin in a dealer-installed radio than a factory-installed one.
--DD
Old 06-21-2004, 09:43 AM
