-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=7)
-   -   OT but think this group will know answer (http://forums.pelicanparts.com/showthread.php?t=169371)
Will98D 06-25-2004 05:08 AM
Looking for a 'super garden tractor', came across a mid-80's Cub Cadet Model 1914 (at least 914 is part of it), 19hp Onan, rear PTO, 3pt hitch, 60" deck, 45" 2-stage blower and a 42" tiller. Anyhow, the thing caught fire about a month ago and has been traded into a dealer who wants $1,800 for it. The question for the group is this: hardly any fire damage because the owner was near the house and was quick with a dry-type extinguisher. However, now the engine bay is full of a couple of pounds of drychem. What is the best way to flush that stuff out of there, hopefully without ruining something else?
Dave at Pelican Parts 06-25-2004 10:07 AM
AFAIK, Nothing.
The popular dry-chem agents, at least the ones in use a few years ago, eat aluminum and also wiring insulation. Often quickly. Jake has a couple of stories about the helicopter engines he used to work on...
The damage is likely already done. I'd walk away.
--DD
mike95125 06-26-2004 09:00 PM
Not all dry chem is the same. Jake was probably dealing with PKP, which is nasty, but some of the dry chem type agents are more innert. If there is any exfoliation of the metal then you will know what type you are dealing with. It should be obvious if the tractor is terminal.
HTH
