-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=7)
-   -   Distributor points wire (http://forums.pelicanparts.com/showthread.php?t=177170)
lmcchesney 08-11-2004 04:23 PM
I'm having a mental block. Does the green wire from the distributor connect to the negative or positive side of the coil?
Thanks,
L. McC
6 Shooter 08-11-2004 05:10 PM
Dist Points Wire
Coil negative. HTH.
lapuwali 08-11-2004 06:21 PM
Negative. The points (or points replacement device) grounds the coil.
