Procedure i'll use next valve adjustment:
-Go to TDC for #1 -hook up leakdown tester for #1 -pressurize the cylinder -set valves repeat for all other cylinders |
From what my mechanic told me... when you pressurize the cylinder it forces the valves closed, so you don't have to worry so much about your setting being off.
Cheers, Elliot |
| All times are GMT -8. The time now is 12:52 PM. |
