Grounding points- where?
O.K. I was told to check my grounds since I have electrical problems. Where are they? I know of the ground strap to the transmission and I see the one above the battery and a bunch of grounds above the relay board. Is there more??:confused: Thanks
There are more ground lug terminals at the top rear bolt holding the engine case together.
In the front fender wells. Up under the dash over on the left-hand side (I think it was left!). Not sure where the others are offhand.
--DD |
| All times are GMT -8. The time now is 12:36 PM. |
