-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=7)
-   -   Compufire vs Ignitor (http://forums.pelicanparts.com/showthread.php?t=192279)
alex9s 11-14-2004 04:49 PM
Which is better compu-fire or ignitor electronic ignition? How is the installation of ignitor in terms of adjustments.......?? Anyone had experience with these?
All opinions welcome!
SGB 11-14-2004 05:13 PM
The ignitor fits really easily, but you must be sure to specify for the right distributor: stock, 009, or 050. I have no experience with compu-fire. Ther really is no adjustment capacity at all. Its like points- on or off based on the location of the distributor relative to the crankshaft... or would it be the camshaft? Well I guess it doesn't matter.
John Rogers 11-14-2004 05:24 PM
When I had the big four in my race car I used a Compufire unit and never had any problems. I have had one in my daughter's 74 2.0L for 6 years and never had a problem with it.
alex9s 11-14-2004 09:19 PM
John, I've had the Compufire for about 3 years with no problems until now. The ground wire going into the module broke off and doesn't look like it can be sodered. I'm away at school(914=only car) and walked to the nearest auto parts store to get a set of points and condensor for a temporary fix. Put them in and smoked the condensor wire b/c I evidently grounded it out by not mounting it. Can this mean the condensor is cooked/bad? Is it possible that I shorted something else while cranking the engine and grounding the condensor wire?
According to the Ignitor description on the website it says it puts out more to the plugs especially with a high-output coil. Any idea?
Thanks for the advice!!!!
Any and all suggestions greatly appreciated!!
sean_V8_914 11-14-2004 11:52 PM
did you let the magic smoke out?
alex9s 11-15-2004 10:17 AM
I'm not sure if I let the magic smoke out but it didn't smell too magical. I almost got a chance to use the fire exstinguisher I've been driving around with for 5 years.
