What do I need for a real leakdown test
I already have a compression tester - what else do I need and can someone explain the procedure?
Patrick, I'm going t point you to a web site about it,
http://www.type2.com/library/engineg/leaktst.htm this should help you get started. |
Here's a link to make your own. I have the parts but haven't had time to finish it yet. http://www.xs11.com/tips/misc/misc3.htm
Thanks guys - I have most of what I need to make one in the garage already. Any suggestions on a better way to build the damper valve other than "fill it with epoxy and drill a hole"?
