How to Remove the relay board in a SIX
I am sure someone has BTDT so please post some photos and or tips on removing the relay board for my conversion.
I have weber 40's Cheers |
When we did my six conversion we decided to leave the relay board in, mainly because we would have had to figure out a wire connector(s) to handle the connections from the two large connectors. I have an internal relay alt in the six so only one wire is connected to the relay board from that and years ago we ran a new tach wire. I did not need a fuel pump relay as it comes off the kill switch and maybe some day I'll replace the board just to clean up that corner?
The 14 pin connector is readily available PN# 911.612.113.05, I got mine from Zim's.
| All times are GMT -8. The time now is 01:12 PM. |
