Banned
Alfred1's Avatar
Been playing with Drag Racing Analyzer
I simulated the acceleration of a stock, 2.0L 914 at sea level and then the same car with a 2.8L VR6 motor. All the conditions and specs were the same except for the different hp and torque values, weight, and the shift points. The VR6 makes 172 hp at 5800 rpm and 173 lb*ft of torque at 4200 rpm and I used 2400 pounds as the test weight for the VR6 car. I also used 5500 rpm for the shift points for the 2.0L and 6500 rpm for the VR6. The tires are street radial 225/60R-15. If the simulations are accurate, the VR6 car should be able to accelerate to 60 in six seconds or less which should surprise a few Boxsters.
2.0L Engine Specs
Transmission Specs
Body and Axle Specs
Wheel and Tire Specs
Driving Specs
Computer Driven Launch Definition
2.0 Acceleration Results
VR6 Acceleration Results
Old 12-22-2004, 04:12 PM
Banned
Alfred1's Avatar
Top speed with the stock VR6 is predicted to be 130 mph but if I add this turbo kit it goes up to 150 mph.
Old 12-24-2004, 08:56 AM
