2.0 liter motor with 1.8 heads
I am looking to build a motor in the near future. I have been hearing from many people that it is good to use 1.8 heads on a 2.0 liter motor. The heads do have slightly smaller valves,but a lot more metal in the head, and less chance of dropping valve seats. I am not looking for a race motor, but just a punchy, reliable street motor, with a mild cam. Any feedback gentlemen???
Old 07-30-2000, 10:28 PM
Send a message via AIM to JP Noonan
The main problem with 2.0L heads is the angle of the spark plug hole increases the chance of a heat stress crack forming between the plug hole and the exhaust port. Once that happens the interference fit between the seat and port is lost and the seat drops.
The 1.7-1.8L don't have as much a problem but then the also don't benifit from the port design and spark plug angle of the 2.0L
There is more to it than just valve size, but 1.8L heads with 2.0L size valves and a big bore kit is going to be a nice motor. With stock 1.8L heads and 2.0L displacement you could bump up the compression ratio a tad to get more power. The biggest thing to get right is to set the whole system up to work together, the cam must match the induction, the induction matches the heads and displacement, etc. Don't put 48mm Webbers on a car with a FI cam and 1.7L heads and expect to go any faster. Talk to the cam manufacture to see what they suggest.
FWIW
Old 07-30-2000, 11:28 PM
check out the difference between the engine sheet metal for the 2 engines. with the difference is spark plug angle, the 2 pieces on engine sheet metal should be different so factor that into your engine buildup
Old 07-31-2000, 05:24 PM
