914fan's Avatar
Front Rubber Pad
I have a perfect front pad with the exception of 2 problems. 2 of the studs broke. (2 problems...... ha ha ha ha....) can they be drilled and tapped or am i screwed. If i'm screwed I'll sell it cheep for a beeellllllliooon dollars...
Any info will be appreciated.
Old 02-13-2005, 07:25 PM
Acox914's Avatar
Send a message via AIM to Acox914
i had the same problem. i took out the plastic piece surrounding them and welded on new studs....
-Aaron
"60% of the time, it works every time"
Old 02-13-2005, 08:16 PM
I f you want to sell it let me know. If you want to fix then you can drill and add a screw or two. I removed a bumper rubber from a bumper and some one had done just that.
I reccomend installing large speed nuts on the bumper rubber studs, they break before the stud breaks oiff.
Craig
Craig C. Laughlin CAMP 914
Helping to bring your 914 into the 21st century.
http://www.camp914.com
Old 02-13-2005, 08:17 PM
