dion914-6's Avatar
Fuel level gauge options
Guys,
I've got a 914-6 conversion with the traditional 911 combo gauge cluster. for oil temp and pressure. That leaves me with no fuel level gauge.
In my first conversion, the previous owner took the stock 914 guage and basicallly strapped it up under the dash so you could see the fuel level gauge sticking down below the dashpad. I'm not doing that again. What other options do I have that will work with the factory sending unit? I'd rather not have to try to find or pay for the 904 style combo gauge.
Thanks for the help,
Dion
Old 02-12-2005, 11:53 AM
A stick? you could go upscale and use a dowel.
Old 02-12-2005, 01:48 PM
Bleyseng's Avatar
Send a message via ICQ to Bleyseng
I took the sender guts out of a stock gas gauge and installed them into a center console oil temp gauge. Scanned and printed a new fuel gauge face and glued it on. Looks stock and is mounted in the center console alond with a CHT and volt meter.
You can also try to find one of these VDO fuel gauges and mount it in the dash.
Geoff
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression)
www.914Club.com
My Gallery Page
Old 02-12-2005, 06:11 PM
Acox914's Avatar
Send a message via AIM to Acox914
I am making 904 combo gauge kits....like the ones that are NLA in pelicans catalog. OIL TEMP< PRESS and FUEL
-Aaron
"60% of the time, it works every time"
Old 02-12-2005, 08:50 PM
ASE Master Tech - 35 yrs
larrym's Avatar
Bleyseng is correct
A VDO VW BUG compatible gage is the one to get; it works fine with the Porsche sender; I posted the part number on some other site about 6 months ago & no longer have it available
My '70 sixer came from Germany setup that way, with the round gage in the console & I recently put in a new VDO gage as in the posting above
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 02-15-2005, 07:51 PM
Put the fuel gauge in the bottom of your tachometer or you can bring your car to me for a restore or custom and I'll give you a 904 combo gauge free and installed.
God Bless You and Your 914
Old 02-16-2005, 07:15 PM
Acox914's Avatar
these will be for sale shortly....
-Aaron
Old 02-16-2005, 07:20 PM
How much for kits? Can you get them with or without the gauges? Discounts on 5 or more like a group buy?
Old 02-16-2005, 08:04 PM
Acox914's Avatar
they are currently in production. almost 50 are spoken for on the 914club. about 100 bucks...
-Aaron
Old 02-16-2005, 08:25 PM
Dion,
I used a stock 911 gauge with both the fuel level and oil level readouts, mounted inside a 914 center console. Yes, I also added an oil level sender unit into my 914/6 oil tank before installing the tank. If you don't want to use the center console, then the triple gauge mentioned by others would be a great way to go.
Lyle
Old 02-17-2005, 08:04 AM
dion914-6's Avatar
I appreciate all of the feedback and ideas. Better than a stick, which I used in high school for my 1940 Chevy streetrod....
I've got my order in with Aaron for the repro 904 part. Just happen to have all of the loaner gauges. Should look great when finished!
Dion
Old 02-17-2005, 07:56 PM
