914-6 3.0
I was wondering if anyone makes a rubber boot for the 3.0 cis so I dont have to cut my factory 914-6
Old 11-19-2000, 08:44 AM
Jim Smolka's Avatar
What ever you do, don't cut the trunk!!!
I have installed a CIS 3.0 into my 914 with out having to cut the trunk. Alot depends on which year CIS system you have. I have an 82 CIS system with a SS air box. The SS box alows the air boot to sit aprox 1" lower than stock. Also, I used a stock 2 hole air boot from Pelican. However, you will need to move the engine lid latch to the other side.
Wayne was able to install a early CIS system in his 914 w/o cutting the trunk.
Suggestions (depending on year)
1. Use a Rich Johnson bulkhead mount
2. Move the engine lid latch to other side
3. Use a SS air box
4. Use the Accumilator and Fuel filter bracket available from Pelican.
5. Assuming a RJ Bulkhead mount is used, mount the engine as far fwd as possible, but still leave a small gap btwn the 2 pieces.
Contact me if you have any other questions
Good luck w/the project!
And when you go for your 1st test drive, remember, it will take a while to get that silly grin off your face
Smoke Daddy
[This message has been edited by Jim Smolka (edited 11-19-2000).]
Old 11-19-2000, 09:55 AM
I guess i'm not understanding.I don't recall seeing the mount you talk about.If i put the engine forward than what happens at the other end?(rear trans bolts?Doesn't seem to me that they will line up.
Old 11-19-2000, 02:01 PM
Jim Smolka's Avatar
Check out http://www.pelicanparts.com/catalog/shopcart/9144/por_9144_sixcon_main.htm
The Motor Mount that I recommend is the Rich Johnson one (PEL-9146-002)
Regarding the adj with the mount, there is a certain amount "play" that is allowed. So, you can mount the engine as far fwd as possible and the tranny will also be OK. This adj is less than an inch fwd to aft.
I hope this helps.
paddlerjim@aol.com
Smoke Daddy
Old 11-19-2000, 04:31 PM
