| BARRY MISHLER |
10-08-2005 03:45 PM |
I`ts a `72 not quite stock, has a `73 2.0 with aries flat top 96 mm pistons,HD valve springs,all internals balanced,mild cam,lightened flywheel,HD oil pump,crane ignition,msd 6a,all that with a side shift trans and stock F.I. with a little tweeking done(still working on that). Bilstein all around w/140 springs also both stock sway bars,195/60/15 tires on Fuchs.Four coats of single stage ppg`77 guards red.Interior is stock with a console from a `73 w/clock,oil pressure,and volt guage.Dash has the combo fuel & temp guage. These mods where made because of what I have been reading here and That OTHER place where I`m known as "72914S" I been driving it for almost two years now.I GUESS i`ll never be done with it. Specially if you all keep coming up with more improvements THAT I WANT TO TRY. HA HA HA http://forums.pelicanparts.com/uploa...1128811529.jpg
