JJ914's Avatar
Porsche Crest Weber Carb Accel cable bracket
Hello,
I am getting ready to put my webers on my car, and I need to know if anyone could send me a picture or drawing on how they mounted the accelerator cable. I assume I need to make some kind of bracket to hold it.
Thanks,
Jason
72' 914 1.7 (Saturn Yellow)
64' VW Type 1
Air Suckers Rule!!
Old 12-19-2005, 06:37 AM
degreeoff1's Avatar
I took a piece of 1"x1/8" bar stock and bent it , then I twisted it in a vise 180 deg(after I drilled a 5/16" hole and through bolted it to the fan shroud (Big hole in front of the oil filler) wala...mine could be prettier but....
Josh
1972 914-6 in the works.....
2003 Ford E-250 "work horse"
2004 Yamaha V-star Classic 1100 "early mid life crisis"
2005 Scion XB "Gas sipping"
1978 Siedelmann S25 "Ataraxia"
Old 12-19-2005, 10:18 AM
thesey914's Avatar
this is another members car but the best fabrication i've seen...
Old 12-19-2005, 01:12 PM
914 Geek
I've seen a setup similar to the first one pictured which loosened up. The mounting bolt didn't hold the bracket snugly enough, so the bracket eventually flopped over to the side. The driver had no throttle, the engine was stuck at idle. He was able to fix it, but the bracket flopped again shortly thereafter.
The second one shown won't do that. A little more thought on my friend's setup would have prevented that, as well. (E.g., a flat section that lays along the surface of the crankcase for an inch.)
--DD
Old 12-19-2005, 01:42 PM
degreeoff1's Avatar
Oop's, forgot to mention that....The hole is drilled as to let the base of the 1" stock sit on the case....I have had no problems...oh did I mention it only took $2 and 15 min to make....:-)
The six conversion that I am in process of doing will be right as rain...
Josh
Old 12-19-2005, 02:50 PM
Stay away from my Member
campbellcj's Avatar
This one worked pretty well IIRC
Chris C.
1973 914 "R" (914-6) | track toy
2009 911 Turbo 6-speed (997.1TT) | street weapon
2021 Tesla Model 3 Performance | daily driver
2001 F150 Supercrew 4x4 | hauler
Old 12-19-2005, 10:14 PM
Wow I like the one in the 2nd picture. SWEET
I made mine to mount on the fan housing. The bracket uses an existing hole just infront of the dizzy.
the bracket is stronger in the fore and aft direction than side to side. a potential problem with pic #1 it will flex under WOT.
Don't think I have any pictures of it handy. Rob Watson might have one as I made one for him too.
Old 12-20-2005, 04:46 AM
Acox914's Avatar
Send a message via AIM to Acox914
here is mine. 1/8" x 1/2" steel stock...
-Aaron
"60% of the time, it works every time"
Old 12-20-2005, 09:17 AM
JJ914's Avatar
Porsche Crest Thanks
Thanks everyone they are all great ideas, I like that 2nd one too. This helps alot. Pelican BBS saves the day again.
Jason
64' VW Type 1
Air Suckers Rule!!
Old 12-21-2005, 12:55 PM
