Bad Oil Leaks
I have a bad oil leak which I thought was coming from the main seal, I replaced the main seal over the weekend. I still have the oil leak. It leaks all over the top of the engine. the sending unit seems not to leak. maybe the oil cooler ? I did not check the oil cooler yet.
I have no idea any suggestions that may help. Chris |
oil cooler seals mostly likely. the fan blows the oil across the top of the engine.
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression) www.914Club.com My Gallery Page |
There are also on gallery ports on the back side of the motor (3 I think). Some folks think that drilling them out and installing NPT plugs.
'75 914-6 3.2 (Track Car) '81 SC 3.6 (Beast) '993 Cab (Almost Done Restoring) Last edited by Jim Smolka; 01-12-2006 at 05:52 AM.. |
914 Geek
In my note to him earlier, I suggested the oil pressure sender, the oil cooler seals, and oil gallery plugs. I also suggested he check to see if the breather hoses were hooked up and the PCV valve as well, and just 'cause it's easy, to take a look at the oil cap and the oil breather tower gasket.
--DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
