-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=7)
-   -   alternator light on tach off when i brake (http://forums.pelicanparts.com/showthread.php?t=260281)
mercl8 01-10-2006 03:55 PM
The altenator light on my 2.0 came on this morning on the way to work. That was odd in itself, but even more odd was that every time I step on the brake peddle the tach and the fuel guage both drop to the bottom. I had to run alot of errands today so I started the car probably 8 or 9 times over the course of the day and the battery doesn't seem run down at all. Any ideas before I pull the alternator? The belt seems to be adjusted pretty well, it could probably be a little tighter. I'm not looking forward to getting at the alternator so I'm looking for other possibilities first ( I know, just replace the alternator) Any advice would be appreciated.
Thanks,
Ron
AaronM 01-10-2006 03:59 PM
Short in the brake light circuit? Tach and fuel guage are electrical, somehow when you're hitting the brakes you're shorting out the power to your guage cluster it seems like.
Aaron
philinjax 01-10-2006 04:25 PM
Replace/clean the fuse S9 and its contact points. All will be okey.
Phil
Dave at Pelican Parts 01-10-2006 04:46 PM
Is that fuse #9 or fuse #8? One of the two is either popped or the ends of the fuse and/or the "fingers" that hold the fuse in are dirty or corroded.
--DD
mercl8 01-10-2006 04:59 PM
Phil.......I love you. (In a good guy, great advice, thank you, heterosexual way).....(maybe I should edit this)
Thanks for saving me from pulling my car apart.
Ron
mercl8 01-10-2006 05:05 PM
Being as observant as i am, i didn't notice the pile of fuses laying on the floor board. I apparently pulled a few out this morning when i set the bag I use to carry files back and forth to work there briefly to run back into the house. Funny thing, its the perfect height for a fuse removal tool. Guess i better find a cover huh?
mercl8 01-10-2006 05:08 PM
Dave......I love you too (Please refer to qualifiers in previous post :) )
mercl8 01-10-2006 05:11 PM
Aaron.......thanks for the response, that was more along the lines I was thinking too.
Jared at Pelican Parts 01-12-2006 05:22 PM
Ive had this problem too. Its the fuse
