PCA & MCSCC Instructor
robfike's Avatar
WTB 912E rear heater blower
I just got my 912E, and I need to find a rear heater blower unit. One of the PO's removed it when installing the carb conversion.
Thanks, Rob
Old 02-20-2006, 04:32 PM
RETIRED
Joe Bob's Avatar
912 E are a one off car.....you CAN use 914 stuff as it is powered by a 2.0 Type IV motor....which is what the 914s used.....of course just to screw with ya...they used a different FI system.
Try a WTB in the classified area.
BTW....if the PO has the FI system or you do....it's a pretty valuable set up. In California it needs the ORIGINAL system to pass smog......the 912 has some very unique parts.
2012 ML350 3.0 Turbo Diesel
Old 02-20-2006, 06:08 PM
Rob,
I have a heater blower that I removed from a 74 2 liter 914 that should work for you. PM me with your e-mail address and I'll shoot you over a picture or two.
Tried to PM you but your mailbox is full.
Gary
Gary
72 steel flared Jaguar Racing Green 2.2 liter "GT"
74 white parts car
74 yellow project car
Old 02-20-2006, 08:03 PM
Rob,
Your mailbox still seems to be full and will not accept any PM's.
Send me your e-mail address and I'll send you a couple of pictures of the heater blower I have available. I also have
a couple lengths of heater hose that you may also need.
Gary
Gary
74 white parts car
Old 02-21-2006, 05:03 PM
Nige-912E's Avatar
I think its also the same blower used on late VW buses
Old 02-24-2006, 08:24 AM
I just went down the the garage and checked my 912 E (#265) and the blower has two outlets like a 914 BUT has a bigger electric moter. Since the motor is clamped to a cradle you would have to have the larger diameter motor to fit. Probably a 911 blower. When I got mine the blower electrical connections were burned up. I had to repair the blower switch as it had bent and was running continiously. The switch is on the heated lever (red handle) .
Old 02-25-2006, 05:28 PM
