914 roll bar trim removal
I am trying to remove the long chrome trim piece on the back of the rollbar (the piece that is the width of the rollbar and about 1/2" tall). What is holding it on?
Brett:
The strip is held in place by clips that are probably quite rusted. Very carefully work one end of the strip outward with a screwdriver and once you get it past the rollbar upright, you can slide the bar off the rollbar. I believe that is what I did 5 months ago. This is one of those cases where you can use gentle force if I remember right. Good luck! ------------------ Herb '72 1.7 Tangerine 'Teen '74 2.0 Red Rustmobile |
That worked! I sprayed a little lube in there too and that helped too. There were three clips. I needed to give it a bit more of a tug than what I thought was necessary.
| All times are GMT -8. The time now is 12:20 PM. |
