r_towle's Avatar
Squeaky clutch pedal
Hi,
sons 74...
Squeaky clutch pedal.
We took out the shifter, look down the tunnel with a mirror, the tube is firmly welded to the tunnel in front and rear.
We did find the accelerator cable was wrapped around the clutch cable...so we thought that was it...nope.
Took the clutch cable off the pedal assembly...the pedal assembly makes no noise.
I am guessing that some chunk of rust may have entered the clutch tube and that is what is causing the squeak...
Anyone else ever had this happen???
We are looking for an easy way to deal with this...hopefully without removing the clutch cable...but it may come to that...
Im thinking..pull the cable housing away from the firewall and shoot compressed air through the tube to dislodge whatever is in there...then shoot a whole can of lube in there from the rear...all the while moving the cable the full 1 foot of play that I can without pulling it into the tube...
Rich
Old 04-10-2006, 05:49 PM
bd1308's Avatar
Send a message via AIM to bd1308
mine did that for 2+ years.....
b
According to Google, "I" am Mike Mueller
1974 914 with 72 1.7 and 74 L-Jet system (vroom)
Old 04-10-2006, 08:21 PM
It may still be the clutch pivot. It may only make noise when it's loaded.
Old 04-10-2006, 08:23 PM
bd1308's Avatar
Rich, I have some bronze pedal bushings coming to me, email me your address and then I can send them to you.
b
Old 04-10-2006, 08:30 PM
SirAndy's Avatar
Re: Squeaky clutch pedal
get a stereo ...
Andy
>> 1970, 914-6, 3.6L (Conversion)
>> 1970, 914-6, #374 (Original)
>> 1975/73, 914 Limo (Custom)
Old 04-10-2006, 08:41 PM
r_towle's Avatar
That is his cure...just turn up the music...
Rich
Old 04-11-2006, 08:11 AM
