What is this 914 tool?
This is from a 1998 Porsche special tool catalog...but I dont understand how it might be used on a 914, do you know?. I assume it is for the transaxle...any other help you can provide? From other tools in this catalog it might possibly be a 914/6 tool, but this graphic is all I have found about it.
Gee, Jeff, it's a stub axle gauge. Says so right there!
![]() My guess is that this is used to install the bearings in the diff housing that support the output flanges and their stub shafts. If so, it's not a 914/6 specific part, and in fact should be usable with any 901 derived transaxle, including the early 911. I've seen a couple of cases where bushing and bearing are used interchangably in English translations of German documents. |
I thought the bearings were mounted to the stub axle shaft this way? Are there other bearings mounted to the case?
but yes, thats how you install diferential carrier bearings
-Aaron "60% of the time, it works every time" |
P69's an early tool number, likely for checking 356 front spindles.
The Cap'n |
Anyone have a photo of P69 in use they can post? The catalog lists it as a 914 tool, makes no mention of it perhaps also being a 356 tool...although that doesn't mean its not a 356 tool too.
