-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=7)
-   -   Window replacement (http://forums.pelicanparts.com/showthread.php?t=293084)
Kevin Lewis 07-12-2006 03:27 PM
Window replacement
I am going to have my front windshield replaced, it's pitted beyond belief. My insurance will cover the replacement, just one question. Does any one know if I should buy new seals for the windshield? I doubt that any glass company here in AZ would know where to get the seals unless Porsche still has them in inventory. Any suggestions before I purchase the seals? Also, do I need the dash seal along with the actual front windshield seal?
SirAndy 07-12-2006 03:37 PM
Re: Window replacement
windshield seals ???
:confused: Andy
Tobra 07-12-2006 04:32 PM
They used to have the dash seal here. If you are going to keep the metal trim, you should get new clips, which are available here. I thought the windshield was held in with butyl tape. Y
ou should replace the rubber you can when you can, it is probably pretty old.
