hardflex's Avatar
need help with fuse board relays
looked in the tech section but couldn't find which relays feed what on the fuseboard inside over the clutch pedal. Trying to get my Wipers working so I can get it inspected. Any help is appreciated.
72 914 2056: 74 9146 2.2: 76 914 2.0
Old 07-31-2006, 05:16 PM
Fuse number 8 is for the wipers. On a 74, it should be a 16 amp fuse.
Gary
72 steel flared Jaguar Racing Green 2.2 liter "GT"
74 white parts car
74 yellow project car
Old 07-31-2006, 07:55 PM
hardflex's Avatar
well, i'm not getting voltage to that fuse, actually reads about .03 volts. Any idea where that might come from?
Old 08-01-2006, 01:41 AM
pbanders's Avatar
Send a message via Yahoo to pbanders
Check out the wiring diagrams on the Pelican main site. It's pretty straightforward to trace it back.
Old 08-01-2006, 11:27 AM
Conrad W Peden's Avatar
Where do i find the values of the fuses if i dont have a cover?
We'll be having an ISO9000 audit soon.
I've divided our preparation tasks into two groups: Unethical and Unproductive.
Old 08-01-2006, 06:26 PM
Here's my fuse reference.
Old 08-01-2006, 10:45 PM
Control Group
Tobra's Avatar
Try go here
Shop Manual in PDF
Old 08-02-2006, 07:25 AM
914 Geek
Easy fuse reference here:
http://www.pelicanparts.com/914/technical_specs/914_electrical_fuses.htm
--DD
Old 08-02-2006, 07:30 AM
hardflex's Avatar
not understanding what's happening here. no current at fuse#8 either pole. If i bridge from fuse #9 to #8, the wipers work, so all is well in the switches and motors, just have to get current to them. hmmmmmm
Old 08-02-2006, 04:08 PM
914 Geek
Which car? The wiring is a wee bit different between 72, 74, and 76 914s.
--DD
Old 08-02-2006, 05:17 PM
hardflex's Avatar
this is on my 72
Old 08-02-2006, 06:40 PM
914 Geek
The "Fresh Air relay" on top of the fuse panel feeds the #8 fuse. Look for red, red/white, black/red, and brown wires going to the relay plug. Check that the red wire has +12V all the time, the red-white wire has +12V when the key is on, and the brown wire has a good ground.
Also try swapping that relay for one that seems to work already.
--DD
Old 08-02-2006, 06:56 PM
hardflex's Avatar
That's what I'm looking for! Is it one of the round black relays like they have elsewhere in the car. I think I have extra's of those.
Thanks Dave!
Old 08-02-2006, 07:20 PM
