-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=7)
-   -   Engine thermostat broken? (http://forums.pelicanparts.com/showthread.php?t=3040)
George Simmons 05-17-2001 06:33 PM
I was inspecting the underside of my '74 2.0 and found that a small wire coming out of my engine thermostat was broken. How do I fix this? Is the wire an integral part of the thermostat? will I need to replace the entire unit or can I just replace the wire. Where does the wire go? You can tell that I obviously don't know anything about this! Help.
TimW 05-17-2001 06:55 PM
The guys at PP said it pretty well:
"Be cooler than all your friends by owning a new thermostat! The thermostat regulates the amount of cool air that flows across the cylinders and the oil cooler when the car is warming up. A proper operating thermostat is essential for engine longevity in a cold climate." - PP
Just buy a new cable for $4.25:
http://www.pelicanparts.com/catalog/shopcart/9144/por_9144_exhaus_main.htm
Part # 021-119-751
It will be easy to replace in just a few minutes. It just feeds up to the top of the engine and attaches to a lever/clamp.
Tim
George Simmons 05-19-2001 12:49 PM
Thanks Tim, I appreciate the tip!
