Post throttle cable installation??
How do I install this new throttle cable that I got from PP? I attached a thin piece of wire to the old one as I pulled it out so that I'd have something with which to pull the new one through. I shoved the threaded-accellerator-end of the cable through the tube under the car, but I can't get it to pull through- even with the wire attached and pulling from the accellerator end. What is the recommended procedure?
Thanks as always.
Old 05-19-2001, 04:33 PM
Post
I cut the old cable and pulled it out. I then threaded the new one in the tube under the car and had no problems with it.
It may be possible that you dont have enough room for both of the cables in the tube.
Hope this helps.
Kelly
Old 05-19-2001, 05:03 PM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
Post
See:www.shoptalkforums.com/bbs/NonCGI/Forum21/HTML/000021.html
[This message has been edited by SteveStromberg (edited 05-19-2001).]
Old 05-19-2001, 07:50 PM
Post
Enrique, I just put one in myself and found that the end of the old cable was still attached to the output pipe in the engine bay. The inside diameter was too small for the threaded end to push through. You might want to check for that.
Old 05-22-2001, 11:58 AM
Post
Enrique, I also had part of my old cable still in the tunnel, you can tell by looking
at where the cable enters the firewall. if there is a silver bell like thing sticking out that is the old cable. pull that out and wahla! the cable will go through like butter.
Old 05-22-2001, 01:10 PM
