-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=7)
-   -   geez - really dumb one here fellas (http://forums.pelicanparts.com/showthread.php?t=3070)
VIPRKLR 05-23-2001 07:59 PM
how much oil in the crank case of a 1.7? I can not seem to convert pints to quarts per haynes and the owners manual...
scg 05-23-2001 08:31 PM
It's about 3.8 quarts (a full 4 quarts if you pour fast on a cold day, leaving a bit in each container http://www.pelicanparts.com/ultimate/wink.gif
Scott
HMeeder 05-23-2001 10:14 PM
Scott is right, but don't forget to add a bit more due to the missing bit in the oil filter when you changed it (you did change it, didn't you?) The full 4 quarts should do it, with a top off from a 5th after you check the levels after you drive it around the block.
Herb
'72 1.7 Tangerine 'Teen
'74 2.0 Red Rustmobile
