Quick six engine bar
Hi--
Can someone help me identify the manufacturer of this quick six engine bar? Also, does anyone know if the design will allow the use of stock heat exchangers and shift linkage (Brad Mayeur, of 914 Limited, thinks that it will)?
Thanks,
--John
Old 12-29-2006, 06:21 AM
RETIRED
Joe Bob's Avatar
the quick 6 bar made by anyone is not what "I" would use. If it's a Patrick Motor Sport one, it has suspect welds.
2012 ML350 3.0 Turbo Diesel
Old 12-29-2006, 06:14 PM
David McLaughlin's Avatar
I had one on my car... it uses stock & unmodified Heat Exchangers and Shift Linkage.
I bought a Rich Johnson mount to replace it though, my car kept jumping out of gear but is just fine now.
1970 914/6 RustoMod
2015 Mercedes E400
Old 12-30-2006, 12:40 PM
JW Apostate
trekkor's Avatar
After I had my PMS bar mount re-welded, I am confident it will not break again.
KT
'74 914-6 2.6 SS #746
'01 Boxster
Old 01-01-2007, 11:16 PM
quick six bar
Sorry for the confusion, I've been trying to add a photo of the engine bar. Can any of you help me attach a photo?
Thanks,
--John
Old 01-02-2007, 08:02 AM
John Rogers's Avatar
Any quick six is not recommended. The long bars at each end flex way too much and cause the welds to break, no matter how good or bad they are. Either the Rich Johnson, factory mount or the new Patrick mount work great. I have a new model Patrick mount and it is also used by many of the vintage 2L conversion race cars. The advantage of it is the engine can be lowered at the rear so the transmission can be pulled out easily at the track or in the driveway. The Rich Johnson mount is like the factory mount but is better made. The factory mount is hard to find and generally expensive to get.
Old 01-02-2007, 02:42 PM
914 Geek
There are a number of "quick six" bars available. The one I call "the forty pounds of steel" bar does not clear the side-shift linkage without some creative modification. I think it might clear the stock Six heat exchangers; not sure about the tail-shift linkage or the stock Six linkage.
I don't like the quick-six approach for all of the reasons above. Some people have made them work pretty well (Hi, Trek!) but I'm not a fan of them.
--DD
Old 01-03-2007, 06:00 PM
JW Apostate
trekkor's Avatar
It's cool. After my welder finished TIGging with chro-mo rod, he said:
"If that breaks, I don't want to be there".
KT
'01 Boxster
Old 01-03-2007, 07:33 PM
RETIRED
Joe Bob's Avatar
You forgot to post what you said when you saw that your mount was broken.....
Old 01-03-2007, 07:36 PM
JW Apostate
trekkor's Avatar
I don't recall...
Link to the thread.
KT
'01 Boxster
Old 01-03-2007, 08:55 PM
RETIRED
Joe Bob's Avatar
In a Jerry Seinfeld sneering voice.....Z O I S......
Old 01-03-2007, 09:00 PM
JW Apostate
trekkor's Avatar
PMS bar mount failure
Mikey, I laughed at that. "Zois!"
KT
'01 Boxster
Old 01-03-2007, 09:17 PM
