-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=7)
-   -   center console (http://forums.pelicanparts.com/showthread.php?t=3377)
Eat-um-up 06-29-2001 07:02 PM
center console
Will a 928 console fit in a 914??
Sweet Blue 72' 914
Check it out at
http://www.geocities.com/eat_um_up/914.html
scotty914 06-30-2001 01:06 PM
well if you look back i posted the same question a while ago and i now know the answer is NO i even tried to build one to fit but the problem is our shifters on the 914 are placed off center to the drivers side and first and reverse are past the center hump so the consol is way to tall and would interfer with the shifter
now i wound up building a custom center consol that looks simiar to the factory one but it fits back to the stock tray ( or optional thrid seat in mine )
scott thacher
75 1.8 on the road again
75 under rust
(fine german rust)
TimW 06-30-2001 07:34 PM
Hey Scott (or anyone), what exactly is that “third seat”? I’ve seen it mentioned many times before, but wouldn’t exactly call a center pad with no seat belt a third seat (if that’s what folks are referring too).
Sincerely,
Curious in Wisconsin.
campbellcj 06-30-2001 09:00 PM
Tim -
It was indeed a center "pad" with no seat belt. There was a pad by itself that didn't have a storage tray under it, and there's also the center tray with the padded lid. They look the same when closed.
Chris C.
odie 07-01-2001 05:33 PM
That third seat does have a seat belt. You just can't seem to get three people across in the car. But that third seat belt is there. I pulled mine out long ago cause it just didn't make any sense. But I still have the seat/pad.
Kevin@ojai.net 07-01-2001 06:17 PM
odie- What year is your car?
-kevin
Eat-um-up 07-01-2001 06:47 PM
Where can i get a seat pad with the stoage compartment?
Sweet Blue 72' 914
Check it out at
odie 07-03-2001 04:46 PM
My car is a '75 1.8...When I bought it 5 years ago, it had a third/middle seat belt installed and it looked OEM. I can't imagine that someone would have even thought about adding one of these on their own.
3D914 07-03-2001 10:12 PM
Weeelll Odie,
I doubt you have my previous 914, but I actually put a third seat belt in my 76. I had two young daughters at the time (both in college now), and the youngest fit perfectly in the center so I added the belt for safety reasons.
I'll probably end up doing it on my 74 also, as I again have two young daughters and two young sons - so the center seat (cushion) will get plenty of use.
Know where I can get a center seat belt?
Regards,
Gerard
74 914-2.0L
<a href="http://www.pelicanparts.com/MotorCity/3d914/index.htm>3D914</a>
Kevin@ojai.net 07-03-2001 11:25 PM
How about just going to a VW junk yard, and geting some good used back seat belts, they are cheap look good, and i am sure will fit.
-Kevin
