-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=7)
-   -   High Idle (http://forums.pelicanparts.com/showthread.php?t=3605)
DSPTurtle 08-02-2001 12:17 PM
High Idle
What would be causing my 74 1.8L from dropping back to idle? It seems to want to hold somewhere between 1,200 and 2,000 depending on where I push in the clutch to disengage the tranny. I can "drag" the idle down by slowly letting up on the clutch and it will hold the lower idle until I accelerate and slow down again.
Any advice???
bowlsby 08-02-2001 12:30 PM
Look for vacuum leaks, an open aux air valve or decel valve. Check injector seals, throttle body gasket and all vacuum hoses.
DSPTurtle 08-02-2001 12:47 PM
Could it be the Decel Valve? The car basically sat in a garage for the last 14 years. It is slow going but at least now I can drive it to and from the parts store http://www.pelicanparts.com/support/smileys/munky2.gif
Thanks in advance!!!
Bleyseng 08-02-2001 01:13 PM
or a leaking oil filler cap gasket.
Geoff
76 914 2.0L
Dave at Pelican Parts 08-02-2001 02:04 PM
Vacc leaks on an L-jet car will often result in a car that idles very poorly, rather than one that idles too high. A malfunctioning Decel Valve might cause the symptoms you're describing.
The ignition timing could also give you these kinds of symptoms as well. Make sure the hoses are hooked up correctly (i.e., if you only have one vacuum fitting on the throttle body it goes to the retard fitting pointing back toward the distributor body, and the advance fitting does not get connected to anything). Make sure the diaphragm in the vacuum dashpot is not broken. Make sure that the points plate moves smoothly when you apply a vacuum to the retard fitting. And make sure that the points plate moves reasonably smoothly by hand as well.
--DD
mejulihn 08-02-2001 04:04 PM
Sounds like a tempermental decel valve to me.
TimW 08-02-2001 07:17 PM
“…depending on where I push in the clutch…”
Clutch plate drag, or might the clutch and accl. cables be binding up?
