p914's Avatar
How much labor is it to install an oil cooler?
Do you have to pull the engine if it's not tapped for an external or does it matter?
Old 09-12-2007, 04:51 PM
Control Group
Tobra's Avatar
Depends on how you do it, there are some that access the oil with a plate between the oil filter and motor, with lines off that plate. Depends on where the external oil cooler is, why do you need one?
Old 09-12-2007, 08:40 PM
p914's Avatar
Think so, the engine is running around 240 with the standard cooler after a rebuild to 2.7 L.
Got one?
Old 09-13-2007, 02:56 PM
