-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=7)
-   -   Lights go off when turning on hi-beam (http://forums.pelicanparts.com/showthread.php?t=411878)
Norway914 05-29-2008 02:00 AM
Hi guys
I have a problem with my head lights. When i change from normal light to hi-beam it all goes dark but if i switch back again it comes on again.
Any idea what causes this?
Have changed the relay where the fuses are for another used one, changed the bulbs and looked over the earth contacts where the head lamps are situated. Also my instrument lights have gone dark but checked the bulbs.
Bjorn
Tobra 05-29-2008 06:15 AM
sounds like either the switch or the relay. Are you sure you changed out the right relay? Do you hear the relay click when you switch over? Try a new one, it is the same relay that is used in a '69-70 VW(pretty much all of them) The VW is $10, the Porsche one is like triple that. Mine had the same symptoms and it was the relay
Norway914 05-29-2008 07:14 AM
Ok, ill try a new relay but it "clicks" when i turn it on and both low and hi-beam is on if i hold the hi-beam lever and does not let it go
Dave at Pelican Parts 05-29-2008 07:29 AM
Sounds like the relay isn't "latching". I can't think of what else would cause that other than a bad relay...
--DD
Tobra 05-29-2008 08:24 AM
mine clicked and did not work
stateofidleness 05-30-2008 09:46 AM
sounds like a fuse to me.
check your fuses and make sure they are seated properly and known to be good
Norway914 06-03-2008 01:49 AM
Yepp, both relays was defective. New one installed and now it works.
Thanks guys!
Sirius Driver 06-12-2008 10:43 PM
I have the same issue. Where's the relay located? I have to change it this week.
Norway914 06-13-2008 12:43 AM
Its located on the backside of the fuse panel. Just unscrew the 2 screws holding the panel in place and you should see it next to the indicator relay.
