rod bushings
Any ideas how to remove the connecting rod bushings. In very tight
Old 06-10-2008, 07:36 PM
Machinist.
They will bore them out and press in new ones and size them to the exact tolerance of your wrist pin. If you don't do this you will not be able to get anything to fit.
Machinists should also do your big end along with balance work.
Old 06-10-2008, 07:57 PM
