daddygo's Avatar
Electrical problem
Trying to help a friend who recently picked up a 73 914 with 1.7L
When the brakes are applied, or turn signal is actuated, the generator light comes on real bright. I'm assuming its a short, I'll find a wiring diagram, but if anyone has any suggestions, I'm all ears.
1973 911T Targa ROW
Old 08-25-2008, 06:25 PM
Always fun tracing those gremlins. Time to start cleaning up the wiring connections. I would start with the rear tail-light assemblies. Take the bulbs out, the assemblies apart, the connections loose.... Clean them all up well... Those parts are very problematic because they tend to get a lot of moisture. And the symptoms you described can be caused by corroded terminals in those areas. Wishful thinking on my part, but I hope that's all it is.
Old 08-25-2008, 09:04 PM
914 Geek
Check the fuses, too. They can pop and still look OK at first. Pull them out and brush the ends and the fuse holders with a wire brush to help them make good contact.
--DD
Old 08-25-2008, 10:05 PM
