New Master Cylinder
So guys, I am going to go through my brakes. I am going to stay stock on the calipers and rotors and am wondering what master cylinder would be the best all around for street driving, 17mm or 19mm?
Old 11-18-2008, 10:02 PM
914 Geek
Lots of different opinions on this. Mine:
Unless you enjoy jumping on the pedal with both feet, stay with the 17mm one. The 19mm one feels "harder" because the pedal moves less, but you also have to push it harder to get the same braking force. Think of it as using a shorter lever between your foot and the brake pads.
--DD
Old 11-19-2008, 07:57 AM
Thanks Dave
I like to think of it as having less hydrallic mechanical advantage, but, what I didn't know was how the pedal would feel. Some people talk about changing out to a 19mm as an upgrade. Wouldn't you then have to then change to calipers with a larger diameter piston to have the same pedal pressure in braking?
Old 11-19-2008, 05:16 PM
19mm an upgrade?
Dave, after my last post I flipped over to master cylinders at Pelican and they list the 19mm as an upgrade!!!!? How soooooooooo???
Old 11-19-2008, 05:19 PM
Does anyone out there have stock calipers and a 19mm master cylinder? I figure the 19mm would take 24.9% more pedal pressure but require only 80% of the movement.
Old 11-19-2008, 05:33 PM
914 Geek
That number sounds about right; it is proportional to the ratio of the squares of the diameters.
The catalog lists what the catalog lists, and as I said there are a range of opinions on the subject.
I have the 19mm MC on my car with stock calipers, and I think the pedal effort is higher than I would prefer. It does feel reasonably stiff though.
--DD
Old 11-19-2008, 09:40 PM
Rrrockhound's Avatar
I have stock brakes with the 19mm MC and even though I've come to enjoy the hard pedal, I would definitely hesitate to let a small person drive--the effort is that high. You tend to think there's something wrong with the brakes until your leg learns what is an appropriate amount of effort.
1980 911 SC
2002 996 Cabrio
2000 Silverado
2011 Golf
Old 11-20-2008, 05:33 PM
OK, that does it! 17mm it will be. I want a lady to be able to make a panic stop in it too! Thank you both for your opinions.
Old 11-20-2008, 11:43 PM
