9magazine's Avatar
How to clean and test oil cooler
Hey guys,
What is the best was to clean and test a 35 year old oil cooler?
Brian
www.9magazine.com
'73 1.7
Old 02-16-2009, 06:15 PM
914 Geek
High-pressure solvent would probably be the best way. You'll need an adaptor plate--you may be able to use an oil-cooler block off plate for that. High-pressure air can find the leaks in a safer way than spraying solvent out any leaks, but it won't clean very well. Solvent will. Push it both "forward", the way the oil normally goes through, and "backward", the other way.
A soak in solvent and some brushes and pipe cleaners can help clean the outside of the cooler.
--DD
Old 02-17-2009, 07:15 PM
9magazine's Avatar
Dave,
Long time no talk! Thanks man!
Brian
www.9magazine.com
Old 02-18-2009, 05:29 AM
