2nd air cooled, help needed,
good morning,
added 914 to garage with 911, need help in 2 areas on 914.
Failed emissions on CO idle, running rich, i understand i can adjust idle rich/lean on ECU, trying to get acess to combustion analyzer, just want to confirm if there is any other problem i will create if i do this, (is there someone in phoenix area that rents analyzers?)
Second problem, is there a way to move the shifter to the right 2-3 inches, or can i buy second shift lever and configure it as needed?
thanks,
Old 04-22-2010, 10:41 AM
racer's Avatar
1) Congrats on the purchase
2) Not sure how you can move the shifter..
3) No nothing about emissions.. other than near me, "classic/antique" etc don't have to be inspected.
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 04-22-2010, 03:04 PM
Control Group
Tobra's Avatar
You can adjust the shifter, try go look in the 914 tech info center, tab at top of page
Old 04-22-2010, 08:26 PM
914 Geek
Moving it to the side by a couple of inches will take it out of the 1st/rev spring-loaded gate, and may very well prevent the lever from going into the 4/5 gate.
If you really need the whole thing moved over, I would consider removing the gear shift lever from the car, cutting it, and re-welding it in a new position while leaving the bottom part the same.
But do adjust it first, just in case it is actually out of adjustment...
--DD
Old 04-22-2010, 08:53 PM
the car shifts great, it's my legs, they get in the way. If I am wearing shoes, I have to lift my leg to shift into first, I will get a second shifter and cut/weld into a better position.
Any thoughts on ECU changes to pass emissions, I have read the dial on ECU only effects idle gas mixtures. If so, is there any idea how small of movement it takes to make noticeable changes?
Old 04-23-2010, 06:25 AM
racer's Avatar
I can't tell from your picture, but I find that a smaller, aftermarket steering wheel greatly enhances room for shifting. Also, not sure if your car has a center console, but mine never did. When I drove cars with one, it felt too tight.
Past:
Old 04-23-2010, 12:14 PM
no center console, will update steering wheel, drove it to work and back this morning, better, as long as i drive in my socks
Old 04-23-2010, 12:52 PM
gearhead
I'm 6' 3" with a 34" inseam. It takes me a little work to get in and out of the car but I don't have any trouble shifting it. I do have a smaller than stock Racemark wheel with a hub extension, so that may help.
It helps us help you if you fill out your profile and list your location. We don't know where you are, and if there was someone local to you, they may offer to come over and help you out.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 04-23-2010, 01:12 PM
phoenix, az. I thought i had it listed and it carried over from the 911 forum, thanks,
Yes, we are close to same size, i have a little extra padding, the steering wheel is not as much an issue as the shifter.
I am still working on the emissions problem, previous owner backdated exhaust to 74, removed air pump/egr. Everything was good except idle CO, still trying to locate exhaust gas analyzer before adjusting but plenty of work to keep me busy on 911, (new suspension)
Old 04-23-2010, 01:59 PM
I'm 6'4 and cured the "shift into 1st gear problem" with the installation of a short shift kit. I had a smaller diameter Momo steering wheel, but I went back to the original wheel with an after market seat that is in between a stock seat and the deep bucket Scheel type seat (see pic). It's a little snug to get in and out with the seat in a reclining position, but otherwise no problem. I think I would try the short shift kit solution before repositioning the shift lever. Regards, Scott
Old 04-23-2010, 02:50 PM
914 Geek
The Rennshift, made by JWest Engineering (which we do sell or at least have sold in the past) is the best short-shift kit out there.
--DD
Old 04-23-2010, 04:27 PM
