-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=7)
-   -   axil out of hub?! (http://forums.pelicanparts.com/showthread.php?t=551)
Porsche914 04-08-1999 07:04 PM
axil out of hub?!
Hey! i am getting there in the few minuts i have to work on my car at night... But how do i get the axil outta the hub? I put the nut on it and tryed hitting it with a hammer.. i have dont this many times on other cars, but it doesnt seam to work with this? I have the axil off at the transmission too...
I need help! LOL
Most stumped,
Michael
wjdunn3 04-09-1999 06:09 AM
It can be tough! very tough.
I am assuming you are talking about the drive axle (with the cv joints attached).
I recommend you remove the axle with the axle stub (hub) attached. then you can seperate the two later.
Remove the large nut from the axle stub (hub). Using a stout hammer or mini sledge / drill hammer, drive the axle stub toward the engine. This is easier if you can heat the trailing arm around the bearing area. You also may want to place something between the axle stub and your hammer for you to strike.
if you don't have anyone to hold the axle while you stike then use some rope to support it .
Once you have the whole thing out, remove the cv joint bolts from the hub end and carefully pry apart the cv joint from the hub. Remember there are two rolled pins between them that provide a tight fit.
This is the toughest part of the whole job. patience and keep at it.
Doug M 04-09-1999 07:40 AM
Dont fight it.If you dont have the right puller IT will be tough.When I did mine Itook the trailing arm off and had the hub and bearing pressed out.I used the puller to install the new bearing.But Iwas planning to change the bushings anyway , if yours are original they need replacing anyway, it made a big difference.But you will have to re-allign the rear wheels.I used a string line for the alignment with good results and the price is right. Good luck
