Distributor vacuum hoses on 1976 2.0
Where does the black small distributor vacuum hose hook on to . I broke it off the distributor when I changed caps . It looks like it wasnt attached to anything but I wanted to make sure. Thanks for the help!!!
Old 07-15-2010, 12:31 PM
racer's Avatar
I thought there was a diagram on this site.. maybe also on 914world? or Auto Atlanta.. I should know since I replaced the lines on my 76 before I sold it.. but that was almost 1 year ago already.
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 07-15-2010, 12:56 PM
914 Geek
If there are two fittings on the throttle body, the distributor vacuum hoses plug into those.
If there is only one fitting on the throttle body, the advance hose from the distributor (that hooks to the fitting that points away from the distributor body) gets run to nowhere.
--DD
Old 07-15-2010, 10:30 PM
