914 headlight problem
Hello, I just purschased 76-914 and last night found out no lights,motors work fine, I check fuse,check wiring at plug in and no voltage any ideas what it could be,Thanks for help?
lights
Check the headlight relay under the main fuse pannel...it should be the square metal one...others are round/black.
If it is the silver metal relay that is clipped to the metal fuse chassis I have had a contact issue there. Seems the relay needs a good ground to work properly. Mine had a home made jumper wire going to the body to ground it. When I removed it my high beams would not work. Haven't resolved it just yet.:confused:
| All times are GMT -8. The time now is 05:38 AM. |
