bcheney's Avatar
Brake Regulator locations 914-4
Does anyone have a picture of where early 70-73 brake regulators are mounted on the lower firewall? I have a six conversion and have been convinced by Eric Shea of PMB Performance to relocate the regulator vs. using a T-fitting since it can't stay in it's original place on a 75 car. I just want to see a pic of the early location. Eric mentioned you can use an early regulator that has the output fittings at the top vs. where they are on a 75 and just use early hard lines as well.
08 Cayenne V6
89 911 Targa Carrera 3.2
75 914-6 Conversion
Old 09-16-2010, 04:25 PM
RETIRED
Joe Bob's Avatar
No pic but puttng in a tee is pretty standard.
2012 ML350 3.0 Turbo Diesel
Old 09-26-2010, 09:48 PM
jamcleod's Avatar
Send a message via AIM to jamcleod
73 914 restoration project
73 914 2.0 CIS #80
74 914 1.8L L-jet
83 911SC
Old 09-27-2010, 04:46 AM
PMB Performance
Eric_Shea's Avatar
If you enjoy flying off the rainy roads backward... two friends lost their teeners. One almost lost his life using "T" fittings instead of the factory pressure regulator (it's not a proportioning valve and it does not restrict the flow to the rear calipers... until you need it to).
Read the page in the factory manual and "understand" what the pressure regulator "is" before giving bad advice.
...just say'n
Eric Shea - PMB Performance
855-STOP-101
We Restore Vintage Calipers
www.pmbperformance.com
Old 11-09-2010, 05:44 PM
Resident Electrician
Mike Bellis's Avatar
Here's a pic with a 914-6 bulkhead mount...
Current Project: 73 914, 1.8t, ~300hp, 930 Brakes, Roll Cage
Past Projects:
69 911, converted to C2 wide body cabriolet 3.2L
72 914, Ford 5.0L V8 EFI
Old 11-10-2010, 09:43 PM
