Hey! Nice Rack! "Celette"
rich's Avatar
Thumbs up Clutch & pressure plate survey
I'm getting ready to place an order for all kinds of stuff with Pelican and others. One of the things I'll need is a clutch kit. I'm looking info and experiences with different types of clutch kits. First I should tell you all. My mission is to build a street drivable car. So double disc hot or cold clutches are out. I've heard of guys using a bus clutch kit buy machining the pressure plate for a larger dia. disc, I've heard of guys using the 911 clutch kit, and I've heard of the Kennedy clutch kit. I'm looking for experiences and ratings on durability, longevity, and and feel. I will have around 300+ hp on tap.
Old 03-05-2002, 09:12 PM
RETIRED
Joe Bob's Avatar
Is this for the 928? Go with the Kennedy, a 228mm flywheel, it's the bus size....kevlar disc and pressure plate....if I could not break it....you should have a hard time doing it....
Z
Old 03-05-2002, 09:43 PM
rich's Avatar
Hey MikeZ, Ya, I'm starting to make a little progress. (I did say a little...)
Old 03-05-2002, 10:06 PM
