Mirror Screw Needed
DOES ANYBODY HAVE A SPARE MIRROR SCREW IN USED BUT USEABLE SHAPE THEY CAN DO WITH OUT
THANKS
scott thacher
75 914 with 2.5 l 98 suby engine on the road
Old 05-01-2002, 08:19 PM
Scott, I added a stock mirror to the passenger side a few years ago and needed two of the special chrome philips screws. New ones seem to be no longer available. I was able to get a pair from PAP in Atlanta (they have since moved), a Porsche salvage yard. You may have to check a similar place in your area. Good luck.
Mike
Old 05-02-2002, 05:57 AM
????? why not go to local hardware store and get a phillips head 6mm screw?? a 6mm x 12mm should be long enough
yes, the porsche screw is actually oval head but at $.25 per screw the "home depot" screw works for what you want
Old 05-02-2002, 06:05 AM
philinjax's Avatar
Scott,
Send me your mailing address and I will send you a good used
mirror screw.
Phil
Old 05-02-2002, 07:40 AM
canna change law physics
red-beard's Avatar
Make sure that the hole has not enlarged by switching the screws between the holes. I installed a new screw into mine, only to find that the hole was stripped. I ended up using a stainless steel sheet metal screw.
James
James
Red-beard for President, 2020
Old 05-02-2002, 07:43 AM
norustscott's Avatar
Just for further info...The screw to attach the mirror is a unique part as it has a slight divot in the threaded area that has a small nylon insert plugging it. The divot is about 2mm and about half way on the threaded shaft. I assume this is to keep the screw from vibrating out. Pretty slick.
Scott
1982 911 SC
1962 sunroof bug
1991 WE Vanagon CARAT WRX conversion
Old 05-02-2002, 07:53 AM
914 Geek
You can substitute the screws that hold the door catch for the mirror screws. They are the same size, are chromed, and look right. I don't know if they have the nylon locking bit in them, though.
--DD
Old 05-02-2002, 09:52 AM
