-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=7)
-   -   Speedo error (http://forums.pelicanparts.com/showthread.php?t=675298)
dmenche914 05-01-2012 05:11 PM
Speedo error
Does anyone know the speedo error that putting 195 50 15 tires will impart on a stock four cylinder 914 speedo? It is probably about 10% or so maybe?
BobbyQ 05-01-2012 05:43 PM
I have a link to a web page with a calcalator for that somewhere. I'll try and find for you.
Found it:
http://www.dakota-truck.net/TIRECALC/tirecalc.html
Enter sizes into "tire A" and Tire B" then hit compare. It'll show a chart with speedo adjustments
rnellums 05-01-2012 05:52 PM
914world has a super sweet calculator too... but its down...:(
John Rogers 05-01-2012 06:46 PM
You can download my GEARS application program from the site here in the tech articles section. It takes gear ratios (as decimal), final R&P ratio (as decimal) and the tire revolutions per mile OR Roll Out which is most accurate and the slider gives speed and RPMs in each gear.
