corner balance
What are the nominal corner balance numbers for the 914. What are yours?
What is the nomnal rear/front ratio? At nominal ride height should the car be flat or have a slight rake with the front lower? Thanks Mark |
Our race car has even side to side weights with me in the car and I can't remember what the numbers are but both front and rear side to side are within 3 pounds. It sits slightly nose down to help it turn in at a corner a little better. Lots of things affect the weight such as the stock gas tank or mine has a fuel cell mounted more forward, is the passenger seat in and what type of driver's seat is installed, is there a dry sump system and where is the tank, where is the batt, mine is in the trunk, etc. Hopefully there is race shop that you can get some help from locally? Good luck.
