911t Fanatic's Avatar
After over a tear finally on the ground!
Got the tranny broke loose and the clutch is working except i cant get first or second. adjusted all of the way out and still no joy. Drove around the block for the first time since i started the resto! any ideas on my clutch issue?
Old 05-06-2012, 12:22 PM
Check that the leakage is right. The cone screws maybe loose.
Old 05-06-2012, 12:51 PM
r_towle's Avatar
I agree, if it's not leaking enough, you may be out of oil.....
In reality, check the shifter linkage, cones screws, and all the bushings to make sure they are all in working order, it may just be the firewall bushing is missing and that might explain why you can't get into the gates.
Rich
Old 05-06-2012, 05:04 PM
OK, I can't spell to whell. I should have said "LINKAGE".
Old 05-06-2012, 05:38 PM
That was funny.
Old 05-06-2012, 06:00 PM
